Bradrord Diff Rebuild
OK I have my Radio in the Bradford but the diff is way over due for rebuild so cant hear the radio...
1/I have the crown out ok
2/The pinion: I have it out, the drive shaft yoke off, the bearing housing off
How do the bearings come off?
I hesident to force or wack anything without knowing If it should be.
Also specs manuals etc for reassembling please
Cheers
Steps.
Edit: Have got the pinion bearing off in the press...
Any info on reassembly, torques, etc would be appreciated still.
